JohnReinagel wrote:Thanks Mike. It sounds like you have your work cut out for you! I wish you great success with that.
The boat I am considering already has the correct pulpit luckily as it did have the gun mount set up, so it's really just the pole and it's mount specs that I will need. I do have a small mill and lathe in my workshop, so depending on how the ends of the poles and the pole mount are, I most likely can fabricate what is needed.
If you have the original specs for the components for the F32 I would appreciate it. Of course pictures of the pole ends would be helpful, but I haven't found any of those either. From what I have been finding, I don't have high hopes for finding the parts themselves.
