Amazing Freedom 45 CC for sale
Use this forum to buy, sell, trade or advertise anything. Non-commercial only.
Postby Freespirit » Tue Mar 06, 2018 9:25 pm
MOTIVATED SELLER
Freedom 45 CC Center Cockpit mono hull sloop
Year:1988 Length:44'11" Engine/Fuel Type:Single / diesel
Located In: New Zealand
Material:Fibreglass/no osmoses ever!
Current Price: US$ JUST LOWERED $99,900.
The Freedom 45 CC is renowned for their build quality, ease of handling and performance. The sloop rig is based on a freestanding carbon fiber mast together with self-tending jib and a real pleasure to sail. Ease of handling, all running rigging lead aft to the cockpit through stoppers to large winches so that sails can easily be handled by one person without leaving the cockpit, perfect for cruising couples. An electric-powered winch for the main halyard ensures that anyone aboard can hoist sail with ease. But what really makes "Free Spirit" shine is her speed while sailing in comfort, with all the amenities of home.
"Free Spirit" has a spacious salon, impressive aft cabin with centerline queen and amazing storage in beautiful cherry and teak. She is a proven, true, blue water cruiser with many custom upgrades, extra navigation and functional equipment (many new in 2016) that make for a very safe and comfortable cruiser/ live aboard.
"Free Spirit" also benefits from a superb hull and deck condition (no osmoses). This boat was designed by Gary Mull and the hull was built by the renowned Tillotson-Pearson Yard to USCG, NMMA, NFPA codes and offshore racing council safety regulations. The brilliance of this design is only really appreciated when single handed short tacking the boat without leaving the helm station. Sailors new to a Freedom need only tack up a narrow harbor entrance simply turning the wheel, while normal boats fight their way with much winching and grunting.
Free Spirit, hull #1 of the Freedom 45 series, without the sugar scoop transom, LOA 44feet 11 inches. She has been maintained and constantly upgraded.
For an illuminating discussion on the Freedom Yachts please refer to Ferenc Mate's "WORLD'S BEST SAILBOATS"
Dimensions
LOA: 44 ft 11 in
Beam: 13 ft 9 in
LWL: 39 ft 6in
Maximum Draft: 6 ft 6 in
Ballast: 9500 lbs
Displacement: 28,000 lbs
Engine
Total Power: 66 HP
Cruising Speed: 7 knots
Maximum Speed: 8+ knots
We have sailed many 190+ mile days on passage
Tanks
•Fresh Water Tanks: 1 Aluminum (70 Gallons)
•Fuel Tanks: 2 stainless steel (98 Gallons)
•Holding Tanks: 2 Plastic (30 Gallons)
Accommodation
Number of cabins: 2 ample
Number of heads: 2
Vessel Walkthrough
•Aft centerline queen with pillow top mattress with drawers and hanging closet Sheets and custom mattress pad included
•Port side vanity with stow away mirror.
•Separate shower stall with pull across shower curtain, shower with adjustable bulkhead mount shower head, seat in shower stall with storage above, additional storage bin.
•Forward large V berth with drawers and hanging closet – ensuite head
V berth mattress foam - new 2017
•Salon (2) single berths with settee including lee cloths
•Salon cushions new in 2006
•Pneumatic custom teak coffee table (retractable)
•Fans, salon, galley and aft cabin
•Wet locker
•Liquor cabinet in main salon
Galley & Water Systems
•1 Blakes Lavac manual head, forward - new 2007
•1 Blakes Lavac electric head in aft - new 2007
•3 way valve for head discharge in aft head
•Separate shower stall in aft head
•Fresh or salt water flush
•Water pressure system, hoses replaced 2014
•Head pump aft rebuilt 2016
•Seaward, propane, 3 burner stove with oven and grill - new 2010
•Little wonder water maker 8 gph, new membrane - 2015
•Cutlery, dinnerware, pans and utensils
•Stainless steel deep functional sink with cutting board half cover
•Corian custom counter tops - new 2013
•(2) Engel top opening ultra efficient maintenance free fridge/freezers, separate compartments (only uses 2.5 amps each) New 2013
•Electric water heater with heat exchanger from engine
•Microwave
•Toaster oven with mount
•Trash compactor
Electronics & Navigation
•Garmin 4212 large screen chart plotter- new 2007
•Garmin GHP12 auto pilot - new 2010
•Garmin class B compact drive unit– new 2016 Includes back up linear drive unit.
•Garmin GMR41 4kw 36 mile radar – new 2007
•Garmin GMI20 multifunction wind/speed and depth indicator – new 2016
•N8XJK Boost Regulator
•Raytheon depth indicator
•ACR Global Fix Pro EPRIB - new 2014
•ICOM IC-M710 SSB radio with Pactor III modem - upgrade 2014
•Garmin VHF200 radio with GHS-20 wireless microphone handheld - new 2016
•5” Ritchie compass – binnacle mounted
•Dual MXD44 stereo with speakers wired through out– new 2016
•Pyle Hydra outdoor stereo speakers in cockpit
Electrical Systems
•Balmar alternator with standby regulator
•Nextgen 5.5kw Genset, fresh water cooled - new 2007 (710 total hours)
•Heart Freedom 25 2500 watt inverter/130amp charger
•4 Renogy (100 Watt each) Solar panels (400 watt total) - new 2014
with Blue Sky Solar Boost 3024iMPPT charge controller
•30 Amp shore power cable
•Link 2000-R battery monitor
•12 Volt DC
•110 Volt AC
•(6) 6-volt golf cart batteries, 600ah – new 2015
•Optima engine start battery
•Dometic reverse cycle air-conditioning unit, 16,000 BTU for salon and aft cabin new 2013
•LED lighting
Sails & Rigging
•Tillotson Pearson carbon fiber mast. Free standing, keel stepped.
No Standing rigging, so no expensive replacing in future
Winches:
•Barient 28+ two speed self-tailing electric in cockpit
•Barient 27 two speed self-tailing manual in cockpit
•(2) Barient 24-45 two speed, self-tailing, stainless steel in aft cockpit
•Mainsheet traveler
•Jib traveler, new car 2015
•UK main sail
•Marshall sails jib – roller furling, self tacking – new 2016
•Asymmetrical spinnaker in ATN sock
•Lazy Jacks
•Manual boom vang, Dyneema, rebuilt 2015
•New running rigging 2015 (except outhaul)
Deck & Hull
•New bottom paint with 4th coat around waterline - new 2016
•45 Lbs Manson Supreme primary anchor (always holds!) with 300 feet 3/8 G4 chain plus 175 feet rode - chain new 2016
•Bruce secondary anchor with 100 ft 3/8 G4 chain, plus rode -chain new 2016
•Lofrans Tigress anchor windlass
•Dual Bow anchor roller
•Fortress stern anchor with 10 foot chain and 200 ft of rode
•Bimini - new 2016
•Cockpit awning and side curtains
•MOB equipment
•(6) Life jackets
•Life ring
•Navigation lights
•Swim ladder
•Magma barbeque
•Bow pulpit and rails
•Side stanchions and lifelines
•(4) adjustable seat cushions – new 2010
•Cockpit table
•Vented propane locker
• 2 Propane tanks
•Fenders new 2016 and dock lines - new 2013
•Foredeck light
•Deck wash down system
•Stainless steel dingy rack on aft deck
•Custom stainless steel boom extension for lifting dingy with motor attached
•Shade cover for 3/4 of boat length, Sunbrella
•Sunbrella covers for hatches, winches, lines, etc.
•Sunbrella shade cover (used to cover dingy when on deck)
•Bomar hatches with mosquito nets and screens for portlights
•Viking 4 man life raft in canister with deck mount – new 2014
•Hard dodger with flex windows
Mechanical Equipment
•Rule Auto bilge pump
•Manual bilge pump
•3 fire extinguishers, new 2015
•Emergency tiller
•Manual wheel steering with chain and sprocket system with sheathed enclosed cables going to rudder post
•Skeg hung rudder has full bearing support – top and bottom
•Propane shut off valve
•3 Blade bronze Max prop propeller - new 2015
•Dometic EnviroComfort reverse cycle air conditioner heater - new 2013
•Sailomat 601 Windvane self steering
Engine Details
•Yanmar 66HP turbo charged engine, 3750 hours
•Dual Racor fuel filters - new 2010
•Fuel shut off
•Electric primer/transfer pump
•Engine alarms
•Raw water sea strainer
•Fresh water cooling
For photos and more info
http://www.sailfreespirit.com/p/free-sp ... -sale.html
Chuck & Lauri
sv Free Spirit
Freedom 42 Hull #1
Somewhere in the Pacific
Freespirit
Return to Buy/Sell/Trade
