Was installing the Jib pole on my Freedom 36. Does the jib pole bend up or down?
1st year putting on sails.
thank you
Richard Abbinanti
installing the jib pole in the sail UP or Down?
- GeoffSchultz
Re: installing the jib pole in the sail UP or Down?
If you're talking about the camber spar, then I always install it with the arch pointing up. I also use rig the boom vang line to pull back on the grommets to get it over the ears on the camber spar.
Geoff;
would you expand on your comment about using the "rig boom vang"?
Ed Reiss
Being There
F38 - #154
out of Marion, MA
Being There
F38 - #154
out of Marion, MA
Geofff
Just wanted to say thank you for getting back to me. I did place the arch pointing up. lucky call.
Regarding the ears over the camber, how far back should that be , as I am on the 1st hole ( slot).
Richard
Richard
I trust Geoff has provided good info on this posting;
http://www.freedomyachts.org/viewtopic. ... par#p34897
Petar
Petar
1986 F36/38
s/v Mirage
s/v Mirage
I actually ripped my headsail getting it over the horns. I now realize ( which may seem obvious ) that the sail was cut to short.
Cheers Dale
Freeform.
Cheers Dale
Freeform.
Petar
Thank you for your posting.
Richard
Richard
