Freedom 40/40 Rigging List
Postby GeoffSchultz » Tue May 04, 2010 6:00 pm
This file contains the rigging specs for the 40/40.
4040_Rigging_List.pdf
(47.62 KiB) Downloaded 465 times
Re: Freedom 40/40 Rigging List
Postby DaysailorJ » Thu May 06, 2010 3:08 pm
Geoff, this rigging list should come in handy. I see that it's the original list for your boat, as delivered, right? Can you tell me anthing about the configuration, at the time? What was the mast height, and were the halyards led to the cockpit? I just ordered a spare main halyard sized at 152' (Endura 7/16 braid), even though I just reduced the mast to 61.5" AWL, whereas your list only calls for 132'
DaysailorJ
Postby GeoffSchultz » Thu May 06, 2010 8:46 pm
DaysailorJ wrote:Geoff, this rigging list should come in handy. I see that it's the original list for your boat, as delivered, right? Can you tell me anthing about the configuration, at the time? What was the mast height, and were the halyards led to the cockpit? I just ordered a spare main halyard sized at 152' (Endura 7/16 braid), even though I just reduced the mast to 61.5" AWL, whereas your list only calls for 132'
Yes, this is the original list that was loose in my manual. This is hull 25, circa 1997, with a 62' mast. All lines run to the cockpit. I'd add 10+' to the jib halyard as I tend to chafe through it and keep shortening it.
Return to Manuals and Documentation
