Mast height F36 cat sloop
Posted: Tue Apr 12, 2016 3:23 pm
by CaptLen
I'm just buying an F36 sloop and have to clear a fixed bridge with vertical clearance of 65'- can anyone tell me what the height above water is for this model? Tidal range is 4.5' which may help...
Thanks in advance for any help
Re: Mast height F36 cat sloop
Posted: Wed Apr 13, 2016 10:25 am
by bad
So a quick look on the internet showed your P dimension of your main (luff) to be 45ft. Even if your boom is 10 ft above the water, that only gets you to 55 ft. You possibly have an antenna or Windex on top, too. You got lots of room...
If you want to double check free advice off the internet... Consider measuring the height. For a conservative measurement, do the toerail to water and using the halyard, mast to toe rail.
Posted: Thu Apr 14, 2016 11:37 am
by CaptLen
Thanks, Eric- We'll be doing the survey this weekend so I'll take my 100' tape measure- thought someone might know offhand. Thanks for the reply.
