Masthead LED for Freedom 25 non-winged
PostPosted: Mon May 09, 2016 10:50 am
by LazyJack
I want to switch out my masthead light for an LED and would like to send someone up the mast only once if possible. Does anyone have the original specs so I can buy the appropriate bulb, adaptor and or whole unit.
Scott
Feel free to text 240-515-7805
Re: Masthead LED for Freedom 25 non-winged
PostPosted: Sun May 15, 2016 6:07 pm
by unfetteredalexandria
If your setup is same as mine, I have one of the Perko combination masthead and anchor lights (see attachment). I was able to replace the bulbs with 2x Dr. LED "Festoon Star." However, it was not installed with the DPDT switch called out in the attachment, so in fact I had no anchor light capability. When I last had the mast out, I reran a 3-conductor bundle and used a diode between 2 "ordinary" switch-breakers in the panel, as the other attachment shows. (I had also replaced the J24 fuse panel with a Blue Seas breaker panel, but you need not do this). The 8A breakers are way oversized for this, but they are there to protect the wire, not the bulbs.
PostPosted: Tue Jun 14, 2016 12:30 pm
by LazyJack
Thanks so much for the help.
