Freedom 28 Cat Ketch Specs
Postby GeoffSchultz » Fri Dec 19, 2008 12:08 pm
Freedom28OriginalPriceSheet.pdf
F-28 Original Price Sheet
(719.52 KiB) Downloaded 1040 times
F28 Specs.pdf
(403.16 KiB) Downloaded 1558 times
Re: Freedom 28 Cat Ketch Specs
Postby peaceandfreedom » Sat Jan 05, 2013 11:13 am
Here are three more files for the F28 CK with fixed keel and conventional booms.
happy sailing
Jim D
F28 CK fixed keel.pdf
owners manual
(1.56 MiB) Downloaded 913 times
F28 CK info.pdf
F28 CK info
(456.12 KiB) Downloaded 798 times
F28 CK Specifications & Options.pdf
specifications and options price list
(167.38 KiB) Downloaded 868 times
peaceandfreedom
Postby VeloFellow » Thu Aug 28, 2014 6:05 am
I believe greg's download is for the freedm 2-28 cat not cat ketch.
Mike
s/v Clave'
1981Freedom 28
Currently sailing Tampa Bay
VeloFellow
Postby cmaxwell » Fri Aug 29, 2014 5:16 pm
I have general specs and rigging info for a F28 wishbone centerboard - I'm looking for sail specs for a wrap-around main and mizzen - or a sail maker who has them and is willing to give them up.
cmaxwell
Location: freedom catketch wishbone-centerboard 1981 tollotson & pearson inc.
Postby Goose13 » Sat Aug 30, 2014 12:41 pm
Haarstick should have the specs for the wrap around sails, I inquired about new wrap arounds for a F33CK. They will try and talk you out of it and getting new one piece sails and going with a track on your mast. Personally I won't go that route because I don't want to drill holes in my masts and looking at the G10 set up I think I'm going to try and go with that. It gives full battans, more roach without adding a track system. I probably won't be getting new sails for at least another year yet.
Goose13
Postby cmaxwell » Tue Sep 09, 2014 5:53 pm
Once up, wishbone sails are the best and easiest to handle single-handed. No one ever mentions the great advantage to having a steady banister to hold on to going forward. I'm still surfing to find sail dimensions. So far no luck.
cmaxwell
Postby Martijn » Wed Sep 10, 2014 3:02 pm
The original wrap around sails were made by ulmer sails, not haarstick. Ulmer sail is now UK sailmakers.
Martijn
Postby 1980raven » Tue Sep 16, 2014 2:39 pm
If you are located in the USA you can contact Thurston Quantum sails, Bristol, RI. Last June I had Steve Thurston out for a test sail on Raven. He took some dimensions of my rig and concluded that my sail are cut (Ulmer) to the original specifications. He indicated he and Gary Hoyt sailed a F28 CK in the early 80s and came up with slightly smaller sails that improved the boats handling, clearence in the cockpit and over the deck. He quoted me about $8k for a new main and mizzen. After looking at other rig posabilities and distilling what others have said on this forum I am keeping the wishbones and the wraparound sails. I haven't ordered new sails yet but I will be some time next year.
Narragansett Bay, RI
1980raven
Postby VeloFellow » Sun Nov 23, 2014 7:02 pm
The Freedom 30 Cat Ketch is the US Freedom 28. Here is the link to he documents which apply to the TPI Freedom 28 Cat Ketch as well. More variation through the years than across the ocean?
viewtopic.php?f=16&t=12051
Mike
s/v Clave'
1981Freedom 28
VeloFellow
Freedom 28 (UK30) cat ketch hull numbers
Postby VeloFellow » Sun Jul 12, 2015 10:35 am
My 1981 Freedom 28 (UK 30) cat ketch is #112
I wondered if the UK builders were assigned starting with #100?
To those of you with Freedom 28 cat ketches or F30 cat ketches in Europe, how about year of production and hull number.
I know the Freedom 30 cat ketch was produced longer in England but curious as to how many and when.
The first Freedom 28 Cat Ketch I went on was #3 built by TPI in 1979.
Mike
s/v Clave'
1981Freedom 28
VeloFellow
Next
Return to Manuals and Documentation
