ketch sailing without mizzen–sail?
Postby PhyshBourne » Tue Jan 23, 2018 1:14 pm
i'm about to buy a freddom 28/30 (u.k.–version) ketch (centerboard–version).
never sailed a ketch before.
i wonder if you always have to have the mizzen–sail up (when – and when not?) – or if you're also be able to sail without it (when – under which circumstances?)?
…there is nothing – absolutely nothing – half so much worth doing as simply messing about in junk–rigged boats…!
PhyshBourne
Re: ketch sailing without mizzen–sail?
Postby andygc » Wed Jan 24, 2018 5:21 am
This video should answer all those questions - a bigger Freedom, but the same cat ketch rig. :D
https://www.youtube.com/watch?v=iFle9YZCzLw
I don't think having the wishbone rig would make much difference.
Feronia
River Exe, Devon
andygc
Postby PhyshBourne » Wed Jan 24, 2018 10:44 am
thanks.
but doesn't sailing without mizzen affects the stability?
PhyshBourne
Postby 1980raven » Sun Jan 28, 2018 9:24 am
I have a Freedom 28 CK with WB booms and wrap around sails. I solo sail a lot in the winter in winds above 10 knots. I usually sail main only due to the difficulty in getting both sails down in 10 Knot winds without someone to keep the boat pointed into the wind. Raven is not as balanced with main only but she sails fine.
Narragansett Bay, RI
1980raven
Postby PhyshBourne » Sun Jan 28, 2018 10:28 am
thanks.
good to know…!
PhyshBourne
Postby Goose13 » Sun Jan 28, 2018 1:56 pm
I have a F33 CK/CB with wishbone booms. I sail all the time with just the Main she sails just fine. In fact With the cat ketch design Freedom recommends sail reduction as follows. Reef mizzen, mizzen full down, reef main, main full down, hold on tight. She does not sail with the mizzen only, you can’t maintain a heading.
Doug and Marie
Goose13
Postby PhyshBourne » Sun Jan 28, 2018 5:49 pm
thank you very much, indeed!
sounds good to me! :)
PhyshBourne
Return to General Sailing
