hi all
I'm redoing the water system on a freedom 33
current water heater is close to 30 years old and I am wondering if anyone has found a replacement water heater that fits in the same place
al
F 33 water heater replacement
Re: F 33 water heater replacement
soundboy wrote:hi all
al
I had Raritan heater on my Freedom 28 CK.
The heater is still in production, so there is direct replacement possible
http://www.jamestowndistributors.com/us ... =9385&BASE
However I learned hard way that the heater was installed into the boat before the deck went in and there is no way to remove old heater without pulling engine out. I cut the heater apart to get it out. I didn't install new heater yet, however there are number of possibilities of every possible shape and size available on market.
CR
I replaced the one in my F-33 with an Isotemp since the dimensions were almost identical. Fit perfectly. I may put some rubber under the straps securing it just for isolation and vibration.
