Y-valve on Pedrick Freedom 35
xluke1
Post by xluke1 »
Hello,
Since I have always operated my '94 Freedom 35 in coastal waters I have never used the Y-valve to exhaust waste to the sea. How does this system work? Is there a need to install a macerator? Does this only affect head black water or does it route grey water as well?
Thanks!
Contact:
Re: Y-valve on Pedrick Freedom 35
Post by GeoffSchultz »
The Y-valve diverts the waste to a thru-hull or to the tank directly from the head. There's no need for a macerator unless you want to pump the tank overboard.
Ereiss
Post by Ereiss »
and sink (gray) water always was going straight overboard already.
Ed Reiss
Being There
F38 - #154
out of Marion, MA
xluke1
Post by xluke1 »
Great info, thanks everyone!
