Fridge Monitor - Tempo Disc
Postby Ereiss » Sat Feb 25, 2017 11:48 am
I'm trying a new solution to monitor fridge temp. It looks pretty good, assuming I get enough range through the insulated walls. The batteries last two years with monitoring every fifteen minutes. I'll let you know how it turns out. Used bluetooth to send info to your phone.
https://www.bluemaestro.com/product/tem ... ta-logger/
(no relationship other than I was looking for a way to easily check the temp)
Ed Reiss
Being There
F38 - #154
out of Marion, MA
Ereiss
Re: Fridge Monitor - Tempo Disc
Postby Tyche » Mon Mar 27, 2017 8:21 pm
Be interesting to hear if it works. Always good to know whether the beer is going to be cold when we get out to the boat and head into Buzzards Bay!
Parsons Clark
TYCHE
Padanaram
Tyche
Postby Ereiss » Tue Sep 12, 2017 6:53 pm
Have used the Tempo Disc and have been very satisfied. Easy to read, via blu tooth, on my iphone anywhere on the boat. I simply put it on the middle shelf. I found battery life, if you don't turn it off, to be several weeks.
Ed Reiss
Being There
F38 - #154
out of Marion, MA
Ereiss
Postby mdedionisio » Fri Feb 16, 2018 2:31 am
I'm getting one of these: http://stainlesslobster.com
A friend of a friend makes them and friend #1 has one and swears by it.
mdedionisio
Return to Plumbing
Users browsing this forum: Google [Bot] and 1 guest
