Fridge Monitor - Tempo Disc
Posted: Sat Feb 25, 2017 11:48 am
I'm trying a new solution to monitor fridge temp. It looks pretty good, assuming I get enough range through the insulated walls. The batteries last two years with monitoring every fifteen minutes. I'll let you know how it turns out. Used bluetooth to send info to your phone.
https://www.bluemaestro.com/product/tem ... ta-logger/
(no relationship other than I was looking for a way to easily check the temp)
