Checking centerboard pin wear f28
How can you tell the condition of center board pin without removing it from hull? How long do they usually last? And lastly do they go into the fiberglass keel or are they supported by the metal that runs vertically in the front of the c/b trunk? Thanks Numbknots
... currently experiencing performance anxiety..,
Re: Checking centerboard pin wear f28
Is there the pin at all? I didn’t open my trunk yet. “Practical Sailor”, in review of Freedom 33 (it is same design, just a bit bigger) says next:
“The centerboard is the product of perhaps the most thoughtful design and engineering on the boat. It is pivoted in a channel, eliminating the need for a pin that breaches the hull.”
So, my take is that it is same type of centerboard as on some dinghies or Tornado catamaran – it just slides there, having pivoting channels on sides.
Or it is not?
Or it is not?
CR
RU,
Seems to me when I opened the trunk to replace the sheaves that were split I saw something different than a channel. In front of the trunk there was an upside down U channel piece. Okay I'll try again. Say the metal is 3/16 thick 4" or 5" wide, bottom open, top end boxed. goes all the way down to bottom of trunk where in the open end appears the pivot pin for c/b. Now does the c/b slide up and down in that U shaped piece?
Why would it. What purpose would that serve? Maybe it does that could be why my center board had play up and down when I had it in the sling. Which is why I had questions about c/b pin wear in the firat place.
I only hope the pin is over engineered because the sheaves really sucked. I put all Garhauler equipment and it really helped ease the lifting. The original parts were small diameter sheaves and like I said befor all split. I changed the line with spectra and striped off the outside coat where it went through the pulleys. Numbknots
I only know how it works in the UK built F33/35. from what you say, I read that the design is the same. The pin does not slide; the U shaped plate is a reinforcement of the trunk. There is a pin below the waterline that can only be removed by chopping away gel coat and filler, after you found the spot where the pin is on the keel (on the outside). I had difficulty finding it because of all the layers of bottom paint. On the F33/35 I believe the pin is 4" stainless.
