F25 Mast Stepping
shaka2
F25 Mast Stepping
Post by shaka2 »
I am interested the Freedom 25. What is the weight of its mast? Can the mast be stepped (and unstepped) without a crane? If so, any advice on how its done.
Re: F25 Mast Stepping
Post by Michel »
If you build an A-frame from two long spinnaker poles or similar, it must be possible. Search this board for a guy named Wilf(red) in the UK. He has an F21 and published a sketch of his A-frame.
shaka2
Post by shaka2 »
Thanks!
(The marina charges $220.00 to step )
hxschiller
Post by hxschiller »
The A-frame must be at least 20 feet tall in order to pick up the mast near its center of gravity.I made mine out of 20 foot 2"x4" stiffened laterally with a glued-on 2"x2". I had a through-bolt at the top supporting a short tang from which I shackled a double block (4-part tackle). The A-frame was guyed for-and-aft using lines to the bow and stern pulpits. I also found it useful to build a little frame, clamped to the bow pulpit that had a trailer keel roller bolted to it. I used this to move mast for and aft when the mast was horizontal. I single-handed the raising and lowering. This required a horn cleat on the side of the A-frame so that one could stop by cleating the hoisting line at any position to take care of whatever.
shaka2
Post by shaka2 »
Thanks for that input.
I have a image in my head on how I'll try and pull this off. sounds a lot eaiser than it likely is.
Wonder how much the mast actually weighs?
Joe
shaka2
Post by shaka2 »
Thanks again guys. I bought the Freedom 25 today after inspecting in 20 knots of wind and snow on the shore of Lake Champlain.
JP
Contact:
Post by GeoffSchultz »
Congrats! Welcome to the family!
