Everything else/portlights
freddie wood
Post by freddie wood »
Dear all,
I bought a Freedom 30(28) cat rigged ketch some years ago.Most of the portlights are leaking because the rubber seal is aged;some of the closing clips are also broken.Are there replacements to be found?Can they be sealed closed?Are any parts available?I would be grateful for any advice.
Saorise
JMD00
Re: Everything else/portlights
Post by JMD00 »
I have a Freedom 28 Cat Ketch and my opening ports are Beckson. If yours are the same here is a link to replacement parts: http://www.beckson.com/replace.html
