We are redoing the propane locker on our F 33. The locker is located in the transom behind the helm. There is a drain hole about and inch above the bottom of the locker that exits behind the rudder. It appears that there is a space between the outer hull and the inside of the locker as I can put 8 " of tie wrap into the hole and not have it appear on the other side. It seems like any leaking propane would have a direct route to the bilge. Anyone have any experience with this ?
al mcguire
" tanstaafl "
jacksonville fl
F 33 Propane Locker Drain question
Re: F 33 Propane Locker Drain question
I have a Freedom 33 which I am doing extensive work on, and have removed the rudder. I will take a look when I go back to the boat in a day or two and let you know what I find. It's not a problem for me as the boat has a Taylors paraffin cooker, so no gas on board.
Roy Denton
Roy Denton
Hi Al,
Even with the rudder off it is hard to see into the drain hole. There seem to be two solid layers of grp with a gap of under 0.5" within the overall thickness of around 1". Probing with a thin piece of copper wire the gap felt gummy, but I couldn't probe very far in due to the geometry. The gumminess could be a thin layer of balsa which has deteriorated, or some kind of deposit which has built up over time. If you are worried you could rake out the gap for a few milimetres, fill with thickened epoxy and redrill the drain hole.
Good Luck,
Roy Denton.
Good Luck,
Roy Denton.
