Through Deck Leaks
dlynch
Through Deck Leaks
Post by dlynch »
Our 1987 F 30 Solitude has enough deck leaks so that, when it rains, water collects in the bilge. The purpose of this post is to ask, besides the bilge, where else is water likely to collect? Even after the bilge is pumped dry, when under way as the boat is heeling the cabin sole is dry but, when coming about, water pours across the sole from the side that was downwind.
Where could the water be hiding and from where is it coming??
Any advice would be greatly appreciated.
Thank you, in advance, for your kind consideration.
Dr. Don
F 30 Solitude
Blue Hill, Maine
