F35 (p) transom dinghy system
Postby Camino » Sat Apr 15, 2017 7:29 pm
Anyone try a Weaver transom hard dinghy mount system with a sugar scoop F35 - Pedrick?
On closer look with the Weaver system - the dink maybe too low and while heeled may cause the dink to drag port or starboard on heeling....
Tom and Stephanie
Good Way II F 35 (P)
1999. Wing Keel 5’
3GM30F, 3-blade maxi prop
Emery Cove, CA
Camino
Re: F35 (p) transom dinghy system
Postby Salacia » Sun Apr 16, 2017 2:40 pm
I use a dinghy tow on my Pedrick 35. It tows the dinghy backwards, raises the stern and only the bow in the water. The towing is great. When day sailing, the dinghy is always ready to go. Pull two lines out of the cam cleats, drop dinghy in the water, undo two hooks and you are ready to go. The only drawback is hearing the noise of the water around the bow of the dink about 6 feet behind the boat.
Stephen Lee
Salacia
F35
Marblehead
Salacia
Postby Camino » Sun Apr 16, 2017 4:30 pm
Interesting. Thanks for this idea.
Tom and Stephanie
1999. Wing Keel 5’
Emery Cove, CA
Camino
Postby philipl » Wed Apr 19, 2017 1:40 pm
Where did you purchase the dinghy tow product?
I am also on the Northshore.
Philip
Philip Leahy
F-38 ex Manchester, MA.
philipl
Postby rvivian » Wed Apr 19, 2017 10:10 pm
Heart's Desire
Freedom 30
Shelton, WA
rvivian
Return to Everything Else
