Lifting strap and jack stand points Hoyt F32
Postby JohnReinagel » Tue Oct 10, 2017 12:07 pm
My marina is going to haul my F32 out in a couple of days and I want to be certain that they know the proper location to place the lifting straps as to not lift with the prop or prop shaft under the strap. Can someone tell me at what points of reference above the water line that can be used for proper strap lifting?
Also, when I purchased the boat it was on a temporary cradle that was too large for the boat which did cause a bit of distortion in the hull from improper placement of the cradle pads. I now have 6 jack stands (shoring stands for those who prefer that term) and would also like to know where the best locations are for these to be certain there is proper support above the hull. Obviously you'd want a bulkhead just above the pad location, but I would think that Freedom recommends specific points, but have found nothing related to this yet. Can any other Hoyt F32 owners describe these locations or better yet send a photo? Thank you in advance./
John
1984 Hoyt F32
Hull #53
JohnReinagel
Return to Everything Else
