F38 Mast Leak, Ready to admit defeat
Re: F38 Mast Leak, Ready to admit defeat
Postby GeoffSchultz » Tue Jun 05, 2018 6:08 pm
I use the halyard to pull the mast ring up when I used adhesive. You have to work your way around it with a putty knife cutting away what you and and pulling from different angles. When it releases, it does so with a bang and may scratch the paint, so placing a cloth around the top edge may be a good idea.
Also, it appears that I misspoke when I said that I didn't worry about water coming down the bolts as I was just forward looking at ours and saw that there was silicon under the washers.
Postby mike cunningham » Wed Jun 06, 2018 11:55 am
I had not pulled the ring and mast for many many years. I also found using halyards helped to get the ring up. One caution, try to apply balanced upward pull on the ring so one side doesn't give causing a ring pitch into the mast.
Postby Ereiss » Wed Jun 06, 2018 3:33 pm
Is it a casting that is brittle? It looked the stsinless bolts may have corroded a bit making it more difficult.
Ereiss
Previous
