Companionway doors
Companionway doors
Postby Monty » Wed Oct 03, 2018 1:24 pm
On our Freedom 40/40, Full Monty (2001), our companionway doors are composed of three panels of heavy plastic, that go in the slides on either side. The companionway is slightly V-shaped (as in wider at the top than the bottom). The panels are inconvenient to store when we want the boat open (we wedge them behind the aft stateroom door). Had had pins put in the bottom panel to act as a bridge deck if necessary. A fellow sailor suggested storing them under the cockpit table (building a custom slide to hold them). I wondered if anyone has tried this. Or found companionway doors that would fit and be easier to use (fold back). Suggestions are appreciated!
s/v Full Monty (Freedom 40/40)
Monty
Re: Companionway doors
Postby germanojohn » Thu Oct 04, 2018 9:15 am
Monty,
On my 40/40, (Hull # 7), there are storage compartments under each step. My boards store in the lowest compartment (second step from the bottom). Nice fit and they are out of the way.
germanojohn
Postby Riki » Thu Oct 04, 2018 11:57 pm
We have a 1997 40/40 and we store the two bottom ones in the bottom stair compartment, although the top one doesn't fit. So we place that one under one of the seat cushions on the starboard settee.
1997 Freedom 40/40 Hull #27
Riki
Postby Monty » Tue Oct 09, 2018 12:12 pm
Thanks for that suggestion. However, our Panda generator lives under the bottom step, so that space isn't available.
Monty
Return to Everything Else
