F38 Rudder Plans and/or Molds
Postby dfurciniti » Tue Dec 04, 2018 3:57 pm
This past season I had an unfortunate event where I hit an underwater ledge and damaged (snapped in half) my 1987 F38 rudder while I was being freed. I know that the F38 is an F36 with a swim platform but I have been informed that there is a different rudder shape for the F38. Does anybody out there have information about who may have the plans and/or molds so that my boatyard can build me a new one? They have not had much luck tracking anything down.
dfurciniti
Re: F38 Rudder Plans and/or Molds
Postby RadioZephyr » Tue Dec 04, 2018 5:46 pm
Call Paul Dennis at Warren River Boatworks. He has dealt with this before and should be able to help you out.
Josh
Sunset Spy
F38, Hull #152
Boston, MA
RadioZephyr
Postby dfurciniti » Wed Dec 12, 2018 3:50 pm
I spoke with Paul and he does not have any molds or plans. He has offered to take measurements of an F36/F38 rudder that he has in the yard. Not sure what that will cost yet but at this point, it is the only option. I wish someone had a mold that would allow my yard to make sure that the shape is as close to the original as possible for performance reasons. The 1987 F38 is actually an F36 with the swim platform added on (this was done until 1989). The F38 was not actually manufactured until 1989.
dfurciniti
Postby RadioZephyr » Wed Dec 12, 2018 4:27 pm
dfurciniti wrote:I spoke with Paul and he does not have any molds or plans. He has offered to take measurements of an F36/F38 rudder that he has in the yard. Not sure what that will cost yet but at this point, it is the only option. I wish someone had a mold that would allow my yard to make sure that the shape is as close to the original as possible for performance reasons. The 1987 F38 is actually an F36 with the swim platform added on (this was done until 1989). The F38 was not actually manufactured until 1989.
Yup, I believe that's my rudder. I had him make up a new rudder bearing for my 1986 deep draft F36/38, so we dropped the rudder and it's not yet been re-installed.
Josh
Sunset Spy
F38, Hull #152
Boston, MA
RadioZephyr
Postby bad » Thu Dec 13, 2018 11:37 am
Not sure if you've tried Foss Rudders
- they have probably made the most rudders. For a one-off you may want to try Phil’s Foils (Google both). They'll tell you what they need to make s duplicate or improve on the current design.
Erik
bad
Postby dfurciniti » Thu Jan 17, 2019 5:55 pm
bad wrote:Not sure if you've tried Foss Rudders
Erik
I just reached out to them to see if they have ever built one for the Freedom 38. Thanks for the input. At this point my boatyard is going to try to get measurements off RadioZephyr's rudder in Warren, RI. I will see if they come back with anything.
dfurciniti
Return to Everything Else
