SEACOCKS
Zengirl
SEACOCKS
Post by Zengirl »
New to sailing and my boat, Freedom32. Haven't had a chance to haul it out and I'm building a reef on the hull. Hull cleaning in the spring. My question is how many seacocks on this vessel and where are they located? Thanks.
RadioZephyr
Re: SEACOCKS
Post by RadioZephyr »
Assuming you have the Hoyt 32 and not the Mull 32, here's a screenshot from the manual showing all the factory thru hull locations:
Thru hulls Hoyt 32.png (133.6 KiB) Viewed 3881 times
Josh
Sunset Spy
F38, Hull #152
Boston, MA
CrazyRU
Re: SEACOCKS
Post by CrazyRU »
Really? You can’t just go and count all of them? Why would you buy an old boat then?
There are at lest three discharge ones. Head (I mean toilet), galley (I mean kitchen) sink and a head sink.
There are at least two intake ones. Engine. Head(toilet) . Previous owner could add one for raw water washing in galley.
That are all located in vicinity of above mentioned devices.
CR
Zengirl
Re: SEACOCKS
Post by Zengirl »
RadioZephyr wrote:Assuming you have the Hoyt 32 and not the Mull 32, here's a screenshot from the manual showing all the factory thru hull locations:
Thanks so much. :D A great help.
