F 35 radar
F 35 radar
Postby Camino » Wed Jan 10, 2018 11:21 pm
A yr and 3 months into this vessel and am now adding radar decided against the usual mast mount and went with a seaview pole mount somewhere off the stern. I don’t have have an exact location yet -will know maybe this weekend if I can stand the cold over night :D Last Thursday’s and Friday things got down right chilly aboard as we were planning the install. The seaview mount looks like a great engineering piece. I like it so far. Radar is WiFi connection so I’ll see how that goes in conditions :lol: Also will fit a mock-up seat perch for the companionway This fits in the companionway slot and is my usual sitting space while underway when thing get bumpy-keeps me looking forward without getting a crook in my neck while auto steers.
Camino
Re: F 35 radar
Postby RadioZephyr » Thu Jan 11, 2018 12:19 pm
I'm also planning on adding a wifi radar on a pole mount off my transom this winter. What radar are you using?
Josh
Sunset Spy
F38, Hull #152
Boston, MA
RadioZephyr
Re: F 35 radar
Postby Camino » Thu Jan 11, 2018 7:25 pm
All my electronics are raymarine -radar is quantum chirp. Kind of want the pole to mount on the transom and go vertical inside my stern rail which bows out a bit there. But I’ll see tomorrow.
Camino
Re: F 35 radar
Postby F32Circle » Fri Jan 12, 2018 10:43 am
We replaced our old Furono Radar with a Raymarine quantum chirp last year. Pole mounted.
The marine electronics folks who did the install highly recommended the cable connection rather than wireless.
We’ve certainly been happy with the result.
F32 Hull #67
F32Circle
Re: F 35 radar
Postby Camino » Fri Jan 12, 2018 11:39 am
Your marine electronic installers are correct! It is much sure-er to have a hard connection into the network. I have used RayControl WiFi for my chartplotters with iPad or iPhone for years. In a run of 8 to 12 hours the iPad will loose signal briefly once or twice in that time period - iPad is usually under the dodger with me. The time outs in WiFi have been in terms of seconds. With this install I’m doing I’ll see how WiFi radar works in my typical conditions and push it with harsher ones. I can always add the data cable later -hope I won’t have to :D Hands down its better your way!
Camino
Re: F 35 radar
Postby Camino » Sat Jan 13, 2018 1:08 am
5 hours work today on radar install - pics show Seaview pole mount mostly assembled sans radar, with LED light installed and radar power cable and LED light wires hanging out the end; and stern mounted pole bracket - giving me less than 1/8" room for nice and vertical pole mount! Another 4 hours needed at my speed.
Camino
Re: F 35 radar
Postby Salacia » Sun Jan 14, 2018 3:03 pm
Here is where I mounted my radar pole.
Stephen Lee
Salacia
F35
Marblehead
Salacia
Re: F 35 radar
Postby Camino » Sun Jan 14, 2018 11:48 pm
Nice shot Stephen - I like the mount. I’d like to know how secure your pole is? Mine is still shaky as shown but hopefully with the long strut mounted to deck it will not budge! I did 2 more hours today - longer doing the install/assembly "singlehanded" :D
Below is radar installed on pole - wrong way (backwards mounted) and right way - took me awhile to figure forward and aft! Next is heat shrink on data cable and LED light wires. Notice the deck gland for the wired thru the transom in the pic. I put that on backwards setting everything up for the haul out of my salon to the deck and had to unstring the cable/wire to reverse it# that was only another 30 min. Mounting the pole was a bear by myself but all worked --some sail ties helped ease the strain and keep the pole sort of level . The pole still needs a 48" strut/brace to the deck to make it really sturdy and I ran out ofbolts ( my remaining ones weren’t not long enough). With just the two rail struts the pole can sway the push-pit railing!
shrink wrap.jpg (42.66 KiB) Viewed 2403 times
Camino
Re: F 35 radar
Postby Camino » Sun Jan 14, 2018 11:50 pm
ok here is the pole mounted - so far....strut to add. And.. wire everything to panel. If anyone wants the life sling bracket shown to right of pic let me know -only cost is shipping to you.....second pic shows new long strut to deck - I will add another small strut from rail to deck to make sure things don't wobble.
Camino
Re: F 35 radar
Postby Camino » Thu Jan 25, 2018 10:36 pm
Spent the day routing the radar power cable and LED light wires to electrical panel. I'm slow. Good news is all works. It took 4 tries to get the MFD to recognize that Radar was in the network. Had me worried about the radome connection mentioned earlier. Good news also is I can use radar via wifi and use my ipad via wifi to the e7 MFD so I think I'm ok not getting Mike's cool wifi attachment. I have to tune the radar next but now am in no hurry.
Camino
Next
