F30 fuel gauge
F30 fuel gauge
Postby lee » Mon Mar 25, 2019 2:38 pm
The Fuel gauge on my F30 (located on top of tank) is not working (it continuously shows a full tank). Can these be replaced or is there a fix to loosen it up? (The tank is currently filled for winter storage)
lee
Re: F30 fuel gauge
Postby Tricia » Mon Mar 25, 2019 11:22 pm
Hi Lee,
The original gauge is a simple mechanical sending unit. You can remove the gauge by unscrewing it and checking to see what's wrong. I'm pretty sure it's a Moeller sending unit: https://www.fisheriessupply.com/moeller-marine-mechanical-sending-units, so if it needs replacing, just measure the arm and order a replacement. When I had mine out and reinstalled it, I used something like Permatex Permashield to seal it to the fuel tank.
Best of luck,
Tricia
1987 F30 "Muse II"
Victoria, BC, Canada
Tricia
Re: F30 fuel gauge
Postby lee » Tue Mar 26, 2019 10:57 am
Thank you Tricia, Just the answer I needed!
Lee
lee
