Exhaust elbow needed for Perkins 4.108
Michel
Post by Michel »
I need a new exhaust mixing elbow for the 1980 Perkins 4.108. I have the elbow that connects to a five bolt flange via a short piece of 1.5" pipe with external NPT on both ends. I fabricated my own elbow from standard natural gas fittings but I cannot get the connection to the flange leakfree. I asked TA diesels for a quote and they want $ 271 plus shipping for just the elbow. When I read that I remembered why I fabricated my own elbow in the first place.
Does anybody have a Perkins part source with more friendly prices? And with shipping to the Netherlands?
This is a photo of the flange on the back end of the watercooled exhaust manifold (I already have this flange):
Five bolt flange
Five bolt flange
And this is the elbow I need (including the 1.5"NPT pipe connection and the 3/4" raw water hose connection):
Mixing elbow
Mixing elbow
Thanks for suggestions.
Robert
Re: Exhaust elbow needed for Perkins 4.108
Post by Robert »
Michel,
Unfortunately these parts for early Perkins 4.107 and 4.108 engines are becoming difficult to obtain, particularly the flange, and therefore dealers pricing has become expensive.
Trans Atlantic Diesel is normally the first place I would try for Perkins Parts in the USA, after that http://britishmarine-usa.com/index.php/about or http://www.foleyengines.com/Default.aspx
I can ony post 2 URL's per message so I will post other replies.
Robert
Robert
s/y 'Magic' - 1985 Hoyt F32
Robert
Post by Robert »
However, why don't you try closer to home. Here is a link to the Perkins-Sabre dealer list in Great Britain http://www.finning.co.uk/_documents/pow ... _sabre.pdf
Also, here is a wholesaler in Britain that may also be able to help http://www.aaamarine.com/servlet/StoreFront
Robert
Robert
Post by Robert »
Finally, here is a company in Italy that lists the 5 bolt flange on their website and may also have the elbow you need http://www.michelecaroli.com/exhaust_elbows.htm
Good Luck
Robert
Robert
THATBOATGUY
Post by THATBOATGUY »
Michael,
The flange has "standard" NPT. Those mixing elbows, like the one pictured, I *think* are aluminum. That's a really poor choice of material for something you are going to run hot saltwater through. You would be much better served to have one built of stainless pipe (just my opinion). There are cast iron versions which work better and a Yanmar one would work well in your application.
The key to getting a good seal is the tapered thread and sealant. I use permatex ultra copper and it handles the heat fine. Make sure and use a stainless nipple between the flange and the elbow and it's a good idea to wrap that with a heat shield. I use the same heat shield used by race car guys for header exhaust and it's readily available from car parts places here stateside.
Last of all, I'll look through my scrap yard and see what I have in terms of spares. If I have something you can use I'll try and get it to an airline pilot buddy of mine and see if we can get it across the pond at least, I know he ends up in Amsterdam from time to time, England more often. I have another friend who has access to international shipping who sometimes does me a favor so with a little gultching we should be able to come up with a better solution for you. Let me do a little digging and get back to you.
George
THATBOATGUY
Update: I don't have one in my junk. The one on Marquesa looks like the one pictured (including the mounting spot for a temp sender) but ours is bronze with bronze pipe nipple connection.
George
marno
Post by marno »
Gday Michel,
Are these a Perkins part? If so, do you have the part number?
Cya
Marno
Marno
F39 Express
Michel
Post by Michel »
Robert, George, Marno,
Thanks for your replies, and George, many thanks for your visit to your 'spare parts center'. As far as I know, the red painted elbow pictured above is cast iron. Aluminum elbows also exist, but these are unpainted, according to the photo's on the TA Diesels website. The mixing elbow is no Perkins part (Perkins stopped at the flange) so there is no part number. There are numerous different mixing elbows used as you can see at TA Diesels.
I redid the exhaust gas leaking NPT pipe today with Locktite 570 (steam pipe sealant) but left out the hemp this time, so the threads have more contact with each other. All other connections on my mixing elbow (10 different parts all with NPT) I did two years ago with Locktite 570 and hemp wrapping (that's how 570 has to be used, they tell me) and they are still tight.
The leaking connection however is turned loose time and again by the weight of the mixing elbow (actually it's an S-pipe) hanging down. Vibrations turn the S-pipe so it becomes undone half an inch. Without the hemp, the S-pipe hangs straight down so it does not turn loose, I hope.
I indeed wrapped it in glass cloth heat wrap like they have on industrial engine installations with dry exhausts. I would have preferred an asbestos wrap because it looks more 'marine'. ;^)
I will go through Robert's links and see what I can find.
