Lost the Rudder!! Help!! F28
Contact:
Re: Lost the Rudder!! Help!! F28
Post by GeoffSchultz »
You can get this information by going to the Freedom 21 site at http://freedom21.info/modifications.htm and bringing up the "Freedom21 Lifting Rudder Design" article.
You'll actually find that article from the Freedom-21 group reproduced here in our archive section.
http://www.freedomyachts.org/viewtopic.php?f=63&t=9506
and the document which is referenced is located here:
http://www.freedomyachts.org/viewtopic.php?f=16&t=9951
Lionel7
Post by Lionel7 »
I lost my rudder on my Mull 28 Hull number 2 which was really hull number one back in 2005. The shaft sheared off right under the hull. I did extensive research at the time, there had been very few rudder failures per my research with Mark Edwards and the guy whose name escapes me who used to run the Freedom factory. The original plans were not available from Freedom who was still in business at the time, and Gary Mull's wife who has a set of all the plans was unresponsive. I had insurance from state farm that was going to pay. I couldn't find any of the companies that make rudders for production boats to do one as there wouldn't be enough orders if they went to the trouble. I finally found GMT Composites in Bristol Rhode Island. They found a 28 near by on the hard and reverse engineered the rudder and built me one. They would still have their plans. Foam core, carbon fibre shaft, carbon fiber skin, it was way high tech. State Farm paid for it all, about $10,000. GMT was fantastic. They did the whole job in a month. I dealt with the president, great follow through etc. Obviously, they are expensive, but the rudder is set for another 20 years. contact me off line if you want more information. I have a lot of pictures. dougpayne48@gmail.com
Doug
Former owner Freedom 28 Hull #2 Free at Sea
Contact:
Just how did they justify $10K for a rudder?!? Never mind, it a custom one-of. What would you have done if you would have had to purchase it yourself?
