Has anyone found there was sufficient room within an F36/38 engine compartment to install a Racor dual filter system such as the 75-500?
Does Racor 75-500 fit?
Ed Reiss
Being There
F38 - #154
out of Marion, MA
Being There
F38 - #154
out of Marion, MA
- GeoffSchultz
Re: Does Racor 75-500 fit?
I can't answer that question, but I will question the need for the dual filter system. It's very nice to have, but is it really necessary? I find that simply having a vacuum gauge on top of a single Racor 500 series filter canister is completely sufficient. You just need to check it regularly and swap the filter when you see it pulling into the yellow zone (or yearly). With the 500 series you can swap out a filter in under 1 minute. No, you don't have the ability to hot-swap filters, but it's a lot smaller in both cost and size. I rarely change the filter more than once a year and I have 4000+ hours on the engine.
Geoff,
I'm almost ashamed to admit it but I do have such a vacuum gauge installed after my current Racor 120 but haven't been able to get it to function. It never shows anything. The racor folks said one way to test it is to gradually shut down the fuel supply while the engine runs and see the pressure. Tried it to no effect.
There is no sign that there are any leaks in my hook-up. Will try calling Racor/Parker again.
Thanks, as always, for the advice and help.
Ed
Ed
Ed Reiss
Being There
F38 - #154
out of Marion, MA
Being There
F38 - #154
out of Marion, MA
