There is something you may want to check on your boat
The boat is Freedom 28 cat ketch 1980. Pics are self-explanatory.
- IMG_0679 (640x480).jpg (180.24 KiB) Viewed 4127 times
- IMG_0676 (480x640).jpg (215.53 KiB) Viewed 4127 times
- IMG_0675 (480x640).jpg (216.54 KiB) Viewed 4127 times
CR
Re: There is something you may want to check on your boat
More pics
- IMG_0687 (640x480).jpg (146.25 KiB) Viewed 4125 times
- IMG_0685 (640x480).jpg (148.12 KiB) Viewed 4125 times
- IMG_0682 (640x480).jpg (157.54 KiB) Viewed 4125 times
CR
last ones
- IMG_0689 (640x480).jpg (143.08 KiB) Viewed 4123 times
- IMG_0688 (640x480).jpg (202.1 KiB) Viewed 4123 times
CR
When I purchased Raven (F28CK) in 2010 the bracket you show was in two pieces. I had a new one fabricated from SS through a local fabricator here in Rhode Island. He made the replacements of both lower pintle & gudgeon for under $500. I provided the old pieces and some measurements he used to fabricate the new parts.
Narragansett Bay, RI
