Hello all
Busy refurbishing my 1987 Freedom 28 and need to replace the prop. Unfortunately the pitch stamp has been obliterated by corrosion. The diameter is 14inch and the shaft bore is 1". Any one happen to know the original equipment specification?
Prop size/pitch Freedom 28
Re: Prop size/pitch Freedom 28
Here is a pic of the prop on my 1980 F28CK with centerboard. I was told that this used to be 14R14 but the former had it cut to a 14R12. It worked fine for me last summer. Be Well, Art
- prop info small.JPG (108.04 KiB) Viewed 3159 times
Narragansett Bay, RI
