F21 Traveler Rail.. broken bolts
Postby Rick@RISE » Mon Mar 16, 2015 8:30 am
Having a hard time finding or even describing the bolt that is broken.
Flat - Counter Sunk bolt, stainless, approx 5", machine thread at the end with the odd nut that sinks flush inside the cabin.
Used to bolt the traveler rail down on top of the cabin.
Suggestions?
Rick@RISE
Re: F21 Traveler Rail.. broken bolts
Postby peaceandfreedom » Mon Mar 16, 2015 9:44 am
The odd nut you are looking for is called a barrel nut. You need to find out what thread this nut is and look for the corresponding stainless bolt. You should be able to find them online. Check MCMaster-Carr
Jim Driebeek
peaceandfreedom
Postby hkowalczyk » Sun Mar 22, 2015 7:49 am
You can get them at Jamestown distributors. Or west marine if you have a local one.
http://www.jamestowndistributors.com/us ... &part=7669
Double check the size of the bolt... the link is from an old order of mine, but since all of the deck hardware has barrel nuts on it I bought two sizes at the time and I don't remember which is which.
http://www.jamestowndistributors.com/us ... &part=6174
While you're at it check the others as well since they're probably rusted as well.
hkowalczyk
