The last storm through Corpus Christi separated my rudder from my f33 swing keel boat. I've about fixed the portion above the water line however I do not know what to expect below the water line.
There appears to be some kind of pin set up, however I'm not sure. Does anyone have any pictures or suggestions
Dwight dwight_tx@yahoo.com
f33 rudder seperation
Re: f33 rudder seperation
See attached photos of 1982 US built fixed keel( would think the rudder would be attached the same for swing keel since the keel stub is the same but not sure).
Thank you for responding, however there was not an attachment to see.
This is a picture of a UK built F35 (aka US F33) with lift keel. I think this is identical with the US boat. I can do a closer view in the next few days, if you wish (and the weather clears up a bit). Hope it is of some use.
Regards,
Gerald
Regards,
Gerald
- fragment of picture taken after re-painting, & before all masking was removed. Sorry about quality.
- rudder.jpg (92.55 KiB) Viewed 6830 times
Gerald Freshwater,
Lerwick Boating Club
Shetland Isles, Scotland
Thank you, that's exactly what I needed. Just an idea what to expect.
Here is an image of the rudder below the waterline a US built F33 with fixed keel.
Happy sailing,
Jim D
Happy sailing,
Jim D
- Rudder of us built F33 CK
- F 33 CK rudder.jpg (200.97 KiB) Viewed 6759 times
THANK YOU !!!!!!!!!!
