venting loop
venting loop
Postby lee » Sun Apr 23, 2017 1:00 pm
on my freedom 30 I have a U shaped pipe with a bolt on top in the top step compartment in my companionway that seems to be leaking a bunch when the engine is running. Is this a vented loop for the raw water cooling system and if so is it stock?
could someone tell me the type (brand?). I would like to order a rebuild if possible.
lee
Re: venting loop
Postby GeoffSchultz » Sun Apr 23, 2017 5:15 pm
Most likely it is a vented loop. You can buy replacement valves from many sources. Here are some at Defender:
http://www.defender.com/category.jsp?path=-1%7C51&id=2234294
Re: venting loop
Postby rvivian » Sun Apr 23, 2017 9:28 pm
I have on on my F-30 and I am certain it was the way the factory installed the engine.
Before I tried to buy a replacement (it does not appear to be a standard one I have seen in catalogs) I would try unscrewing the top and cleaning it.
rvivian
Re: venting loop
Postby mike cunningham » Mon Apr 24, 2017 7:33 pm
Agree with Heart's Desire. Been there done that. Agree with dissambely and cleaning. That worked for me.
Re: venting loop
Postby lee » Mon May 01, 2017 10:37 pm
Thanks guys. Cleaning this weekend will be my next move..
lee
