Stern Tube Length on F38
Postby Ereiss » Wed May 30, 2018 9:15 am
I need to slide the Tides Marine shaft seal forward a smidge to see it that will stop the leaking. Does anyone have an approximation of how long the stern tube is? I assume (betting the boat on this) that moving it 1/4 - 3/8 will not create a risk.
Wish me luck.
Ed Reiss
Being There
F38 - #154
out of Marion, MA
Ereiss
Re: Stern Tube Length on F38
Postby RadioZephyr » Wed May 30, 2018 11:09 am
On mine, it's just long enough for the two hose clamps on the Tides shaft seal.
Josh
Sunset Spy
F38, Hull #152
Boston, MA
RadioZephyr
Postby gamayun » Wed May 30, 2018 12:25 pm
RadioZephyr wrote:On mine, it's just long enough for the two hose clamps on the Tides shaft seal.
Same with mine....
Kynntana, Freedom 38
gamayun
Postby Ereiss » Thu May 31, 2018 5:00 pm
I guess moving the shaft seal 1/16 or 1/8 movement forward could be my limit. Thank you both.
Ed Reiss
Being There
F38 - #154
out of Marion, MA
Ereiss
