Pedrick F35 rudder bearings....
Postby FreeB » Mon Dec 17, 2018 1:04 pm
Anyone have any photos or assembly drawings of the rudder-post-bearings setup for a Freedom 35, mid 90's vintage? Appreciate any help you can provide.
FreeB
Re: Pedrick F35 rudder bearings....
Postby bobr » Mon Dec 17, 2018 6:25 pm
I'm not sure if it is in the owner's manual, and mine is on the boat, asleep for the winter.
If you do not have access to the manual I'd be happy to check it, but it may be a while.....let me know.
Bob R.
1995 Freedom 35 (Pedrick)
"Liberty"
Old Saybrook, CT
bobr
Postby BillSmith » Tue Dec 18, 2018 12:45 pm
Attempting to attach schematic from manual.
F35 Rudder.jpg (192.47 KiB) Viewed 825 times
Bill & Carole Smith
Freedom 35 Pedrick
SweeTART
Coyote Point
San Mateo, CA
BillSmith
Postby Salacia » Fri Jan 04, 2019 7:22 pm
Sorry to be late on replying to your email. Holidays and finding the pictures slowed down the process.
Tides Marine makes the rudder bearing. Give them your year and model and they will guide you to the proper size.
A couple of years ago, I towed a lobster bouy overnight caught on the rudder post while sailing to Maine. (I was doing 5+ in 12k of wind. I was happy.) I ended up having to replace the bearing. Tides was out of the model. I was at a good yard that had a machine shop. (Name of the yard is withheld for reasons you will see.) They made a replacement bearing to Tides specs.
copy of Tides bearing.jpg (7.65 KiB) Viewed 640 times
Rudder reinstalled. Once in the water, I found the rudder was hitting the bottom of the boat when I turned. A collar was crafted that could be installed without pulling the rudder again.
collar prepped.jpg (9.03 KiB) Viewed 640 times
(I did have to pay for a second lift even though their work allowed the rudder to hit.) I've seen similar collars on other Freedoms.
collar installed 1.jpg (7.27 KiB) Viewed 640 times
Best of luck.
Stephen Lee
Salacia
F35
Marblehead
Salacia
