Coolant conditioner
mike cunningham
Coolant conditioner
Post by mike cunningham »
Its been way too long since I've flushed the coolant system. So long that I've forgotten what conditioner I used last time I flushed. I could go to the parts store and buy an off the shelf product easily enough but wondering if anyone has a recommendation. I have a 30 equipped with a 2GM20F.
Mike
Mike Cunningham
Freedom 30 (Mull) Hull #3
Re: Coolant conditioner
Post by Michel »
I had a badly crusted up cooling system; the PO's had apparently topped up the engine with Mobile Bay mudwater. I tried automotive cooling cleaner but eventually used the stuff from the DIY shop that is used to cure clogged up sewage pipes. It's a liquid that contains caustic soda. I tried first if it would damage rubber (no) plastic (no) iron (no) and aluminum (yes). I let it circulate for half an hour in the engine under load until it was hot and then let it run out with speed through the largest drain I could find, which is the water side of the oil cooler on my Perkins 4.108. Then I flushed the engine and bilge twice with fresh water. To see if the dirt was gone, I left a third batch of fresh water in the engine for the rest of the season. After 15 hours of running the fresh water was still transparant, so I replaced half of it with anti freeze.
THATBOATGUY
Contact:
Post by THATBOATGUY »
For the Yanmar I would use the Yanmar product. I would *not* run with just fresh water only. The antifreeze also lubricates your water pump. I doubt that 15 hours hurt it much though. I use distilled water when I mix my own antifreeze and for topping up the engine to prevent scale.
