It's no one particular thing, just a very edgy feeling. I've spent the better part of my life moving things around for a living, mostly explosives. I held a Class A CDL with an X endorsement. But a bag of water is *not* the same as a taught line being fair led through blocks. It's dynamic. A boat wake at the wrong time could get it moving in a way you didn't expect. The most dangerous loads I've ever handeld were beer in cans and bottles because of the way the weight would shift. Each little tiny force of liquid shifting a little bit to one side in a turn adds up to a big problem if you let it.
Anyway it sounds like you have a handle on things and are thinking through the possible problems, just please be careful.
Mizzen sheet on F39PHS (also mast climbing)
- THATBOATGUY
Re: Mizzen sheet on F39PHS (also mast climbing)
Mike
In one of your postings here you said your sails are now loose-footed. Did you have each clew reinforced or simply use 'as is'?
Brian Kerslake, PHS 39 'paradox', Brighton UK
F39 (1988) PHS 'Paradox'
Brighton Marina, UK
Brighton Marina, UK
Gidday Brian,
The sailmaker that made the stack packs advised me to use the sail as is. It seems to me that running the bolt rope along the boom didn't actually give the sail much extra support and the load on the clew does not appear to be any greater.
Cheers,
Cheers,
Mike Holibar
Lyttelton
New Zealand
Lyttelton
New Zealand
Re: Boom
Just came across this in an online Uk catalogue. Interesting to see how similar it is to Michel's climbing kit idea...
http://www.mailspeedmarine.com/sail-con ... 3603.bhtml
Brian Kerslake
F39 PHS 'Paradox', Brighton Marina, UK
PS Where a very nice F35 'Goldrush' arrived yesterday, stayed one night then headed off to Wisbech on the east coast of the UK.
Brian Kerslake
Brighton Marina, UK
Brighton Marina, UK
Yes, the Wichard gybe-easy is very similar, but because the word 'marine' or 'boat' is somewhere in the brochure text, it's 10 times more expensive as an abseil/rappel eight. If you look in the catalogues of mountain climbing suppliers, you find similar items for under 20 UKP. Like these:
I've seen the ads for Goldrush when she was for sale. Must be one of the very last F35 catketches built. I collect pics of all goodlooking Freedoms I can find:
Hi all,
just to let you know I now have my mast climbing water bag. Fyne Spirit is on the slipway at present and wont be back in for a couple of weeks. But when she is I'll give it a try and let you know how it goes, maybe with photos. I also have the grigiri, harness and ascender system, but I am a lazy so and so and the bag system looks a lot easier.
Best wishes,
Best wishes,
Mike Holibar
Lyttelton
New Zealand
Lyttelton
New Zealand
By the way Michel, that is a nice picture of Gold Rush. I like the arch down aft and the wind generator mounting location. It looks more practical and versatile than the foremast mount on Fyne Spirit. Is there a shot from the beam which would show the location of the mizzen sheet in relation to the arch?
Cheers,
Cheers,
Mike Holibar
Lyttelton
New Zealand
Lyttelton
New Zealand
- Peter
- Location: Bremen, Germany, UK F35 CB Cat Ketch 'Avante'
Hi Mike,
here are some pics of Goldrush I found in mmy archive.
Hope this helps!
Regards
Peter
ps Not only Michel collects pictures of good looking Freedoms
Hope this helps!
Regards
Peter
- AutoProp1.jpg (61.77 KiB) Viewed 7975 times
- exterior3.jpg (67.31 KiB) Viewed 7974 times
- exterior2.jpg (67.12 KiB) Viewed 7974 times
Peter, thanks!
I like the deck level stern platform on Goldrush. Aesthetically very well done, as is the arch.
Thanks Peter,
the picture paints a thousand words.
Mike Holibar
Lyttelton
New Zealand
Lyttelton
New Zealand
