Reefing Blocks in Boom
Re: Reefing Blocks in Boom
Postby Camino » Wed Nov 01, 2017 10:24 am
Lee- there may be other methods but I suggest you carefully drill out the rivets, then carefully drill and tap with 10-24 (recommend using a combo drill-tap bit as it makes a one shot procedure), remove the end cap with reefing lines and outhaul attached. Once the cap is off you can pull the blocks out to inspect them, untwist, run new lines using messenger lines to the blocks, etc.
Camino
Postby lee » Wed Nov 08, 2017 1:43 pm
Thanks Camino, I was thinking along those lines. Is there any reason to remove both caps or will it all come out removing the aft end?
lee
Postby Camino » Mon Nov 13, 2017 11:30 am
There are other threads on this site about those butterfly or shuttle blocks This thread here viewtopic.php?f=9&t=12353&p=48916&hilit=Butterfly+blocks#p48904 shows a diagram. With the end cap off, you can pull the shuttle blocks right out. You may need to wrangle a bit with the forward lines entering the boom from the mast to allow enough slack to pull out.
Camino
Previous
Return to Rigging and Sails
