Stack Pack and Tides marine track
Posted: Fri Apr 04, 2014 4:54 pm
Re: Mainsail Handling
Sent: Fri Apr 04, 2014 3:30 pm
To: wcwcwc
Bill,
Yesterday, I took a fredoom 38 to survey. Everything went great, but you should have seen the rolling comedy show that was 5 guys from Annapolis Yacht Services trying to put the sails on the boat. They were scratching their heads for some time before they figured it out. The only real problem with the boat is that it has the original Harken bat car system. It was a real workout raising the main.
I've always thought the Tides Marine track look like the way to go, and I read in the Freedom group that you have both the TM track and a Doyle Stack pack. That is exactly the set up I want to upgrade to. My questions are about the installation. Did you install the track and stack pack yourself? If so, any words of advice?
Lance Smith
Baltimore, MD
S/V Magic Dragon (maybe... still trying out names)
Answer to above:
Lance: I had a Tartan 30 with the Doyle Stack Pack then a Freedom 36 with the Tides Marine track and a Mack Pack with a Haarstick full batten main.
The Tides sail track came with the boat and I can't say enough good about it. Sail came down like a freight train and went up with quite a lot of effort but less than if the track was not so good. Don't forget that the sail weighs about 150 pounds.
The Mack pack was good and cheaper than the Stack Pack but not as easy to use. Either of these are better than a separate cover. When the sail was lowered into the Mack Pack it needed to be flaked/wrestled into the pack and took quite a bit of effort to zip up or unzip because the Mack Pack's upper edges are Sunbrella fabric and the lazy jacks don't hold themto receive the sail.
The Stack Pack had a somewhat stiff upper edges which included a pvc tube and were held up by the lazy jacks. On the Tartan this resulted in very little flaking/wrestling and a gentle tug on the zipper line to zip/unzip. Remember that the Tartan, while it did have full battens, did not have as much roach as the Freedom so it may not be directly comparable.
I'm posting this and your message to me in the main discussion rather than in a the PM area so others can benefit as well.
I sold the Freedom in October, 2013.
To: wcwcwc
Bill,
Lance Smith
Baltimore, MD
Answer to above:
