F25 GUN MOUNT REPAIR
markmuk
Post by markmuk »
The white plastic inside the spinnaker gun mount of my just-acquired F25 was broken up and it was really tough to get the pole to slide through. I removed the mount, knocked out what was left of the 1/8" thick plastic and epoxied some similar-thickness, synthetic carpeting in it's place. After a generous application of "Liquid Rollers" (a spray used to lubricate boat trailer bunks that I happened to have on my garage shelf ;) ) to the "carpet bushing", the pole now slides through easilly (without any rattles).
Now it's time to put it all back together on the boat, rig it up and sail! :mrgreen: :P
RussNelson
Re: F25 GUN MOUNT REPAIR
Post by RussNelson »
How did that work for you?
I'm 3D printing a new sleeve.
1982 F25, hull 047 round mast.
johncd3141
Post by johncd3141 »
What filament material are you using?
iansan5653
Post by iansan5653 »
Oh interesting - 3D printed PETG could work well, though I'd be worried about the increased friction of the full tube. Though maybe it's better since it distributes loads better? How will you secure it in the gun mount?
I personally used UHMW strips (https://www.mcmaster.com/catalog/7701T91). It was pretty easy to cut them to the length of the tube, drilled and countersunk 1/4" holes, and used nylon bolts to secure them (https://www.mcmaster.com/catalog/92929A222 and https://www.mcmaster.com/catalog/94922A325). Not the cheapest solution though once you factor in shipping. $18 for those nylon cap nuts is absurd, but I guess McMaster never claimed to be affordable.
3 years in though and it's still working perfectly.
Ian Sanders
1983 Freedom 21 - Shoal Draft
St Petersburg (Tampa Bay), FL
