climbing your unstayed carbon mast, your experience?
VeloFellow
Re: climbing your unstayed carbon mast, your experience?
Post by VeloFellow »
Thanks for all the comments. I had been looking at atn mast climber, the negatives have been related to ascenders scratcing/damaging mast. Do you pad yours?
Mike
s/v Clave'
1981Freedom 28 #112
Currently sailing Tampa Bay
yanmar 2ym15 2blade prop
daletournier
Post by daletournier »
Hi, I also use the top climber with a second safety line. And also find the only issue is not being quite high enough at the top.
Cheers Dale.
CaptLen
Post by CaptLen »
I' e been up with both a bosun's chair on the halyard and the ATN Top Climber. I like the top climber as you can use it yourself. However, as pointed out it is hard to get up over the top of the mast. My F36 ketch had two halyards on each mast; the F36 cat sloop I'm getting does not so the hint on the safety device should be heeded. I lack a power winch on either boat
lewharve
Post by lewharve »
I have been up 5 times using a tope climber, but for me it is a killer. and with the hole in the bottom of the mast I could not do anything. but I sent my wife up in a boson chair and the electric winch very easy.
