Vang connection on F30
Postby lee » Wed May 24, 2017 11:31 am
The ring at the base of my mast that connects the mast end of the boom vang (the center ring) has been broken off. The previous owner has crimped a wire between two of the other rings to the vang which looks dubious at best. I was wondering if anyone else had an idea for attaching the boom vang to the mast. I have seen a heavy duty metal cuff that surrounds the mast that was probably fabricated for the boat, but if anyone knows if this is a item that can be purchased I would love to know. I would be open to any other good ideas. Also are these rings a known weak point?
lee
Re: Vang connection on F30
Postby jdpandlp » Wed May 24, 2017 12:49 pm
I had the band you are describing made by Garhauer Marine when I installed rigid vangs on my Express 39. I would recommend Garhauer.
jdpandlp
Postby gamayun » Wed May 24, 2017 9:08 pm
Garhauher Marine sells this for the Freedoms. I bought one for my F38 about 4 years ago, so don't recall the details, but they'll size it for your mast. They need the diameter of your mast at the bottom and about 9 inches off the deck, if I recall correctly. Just give their tech support a call (909-985-9993). I also bought the rigid vang to hold up the boom. Excellent upgrades for the boat....
gamayun
Postby lee » Fri May 26, 2017 11:40 am
Thank you. I have contacted Garhauer marine.
lee
