doing work on the 40/40 mast
Postby Laisve » Wed Apr 04, 2018 11:38 am
Hello fellow Freedom lovers,
we need to replace the broken windex on our 40/40. I was wondering how safe the bendy CF mast is to climb, and would you advise doing so?
Thanks!
Freedom 40/40
Portsmouth, RI
Laisve
Re: doing work on the 40/40 mast
Postby Ereiss » Wed Apr 04, 2018 12:22 pm
I have gone up my f38 mast many times with my climber. Never worried.
Ed Reiss
Being There
F38 - #154
out of Marion, MA
Ereiss
Postby GeoffSchultz » Wed Apr 04, 2018 10:08 pm
The mast is not that bendy and I've been up many times. Just be sure to have a safety line along with the primary line. When you get to the jib box, you'll have to release/tighten the jib/spinnaker halyard and let some play out as you're now bypassing it. Just be very careful once you move past the jib box as if your main halyard were to fail, you'd fall up to 2x the distance between the jib box and the top of the mast. That's about 15', so make sure that your halyards are in good shape. As I said, I've done it many times (I like to go up to do photography), but just be aware.
Postby Laisve » Thu Apr 05, 2018 11:17 am
Thank you! Can you guys elaborate on your climbing setups? I've never climbed a mast.
Freedom 40/40
Portsmouth, RI
Laisve
Postby BillSmith » Thu Apr 05, 2018 12:21 pm
Bill & Carole Smith
Freedom 35 Pedrick
SweeTART
Coyote Point
San Mateo, CA
BillSmith
Postby Camino » Thu Apr 05, 2018 3:00 pm
I posted this yesterday and took it off - redundancy :D What they said....
I use either a climbing harness or a west marine bosuns chair. My other boats I used the ATN mast climber. The mast climber takes a bit of time-practice to develop the right technique. On my F35 I use the main halyard secured with a bowline not the shackle to the gear I’m in. I wrap a line around the mast with two carabiners as a safety line. I use the power winch to haul me up with wife on the button. I wrap with 4 wraps on the winch drum going up. if the button sticks in the on position and won’t stop she knows to simply Unwrap the halyard from the winch. With two turns on the winch only, she easily lets me down no problem. Halyard needs to be in good shape, As mentioned. To get above the mast head for top work, I tie a sail tie to my harness with loops for my feet like stirrups. I adjust the loops to allow me to stand up and gain another 2 ‘ height
Bills link is good btw -if you go that route might as well get the ATN mast climber ( he’s a good guy and his kit is well engineered)- again with practice you’ll scramble right up - with two people the power winch is easier :D
Truth be told, the first time up my unstayed mast to the top I thought I was going to pass out! I wasn’t used to no stays, no spreaders, no backstay, etc. the top was a bit bendy and I freaked. I asked to be let down. Got my senses and went up again in 15 minutes , all ok. Very secure and safe
Camino
Return to Rigging and Sails
