Knot for reefing lines
Postby lee » Fri May 18, 2018 11:41 am
Just redid all my reefing lines and outhaul. I currently have two hooks I purchased for reefing lines at the luff grommet of the sail. It is clunky and the hooks can pull out when the sail comes down.. am I OK just feeding the line thru the grommet and tying a figure 8 knot in it? Will this be strong enough or is there a better knot?
lee
Re: Knot for reefing lines
Postby Paul Langevin » Sat May 19, 2018 9:37 am
Lee, I use a small bowline at the luff on the two reefing lines on our 40/40. Never had a problem
Paul Langevin S/V StarStruck, Freeedon 40/40
Paul Langevin
Postby Salacia » Sat May 19, 2018 10:09 am
I use a figure 8 and add a large washer between the knot and the sail to ensure that the knot doesn't pull thru.
Stephen Lee
Salacia
F35
Marblehead
Salacia
Postby bad » Sun May 20, 2018 9:17 am
A knot will tend to pull the gromet into the horizontal plane and depending on the loads that may be an issue for your sail or sail track. The purpose of the hook is to keep the loads in the vertical plane. You can also run your line through the gromet and attach it low to the mast on the opposite side. That is similar to what it's done on leech reef points.
Erik
bad
Postby lee » Tue May 22, 2018 6:32 pm
Thanks for the responses. I can see the issue in keeping the stresses on the horizontal plane to avoid stressing the sliders and track. I’m going to try and rig them back to the boom and see how it goes. Thanks everyone for your responses.
lee
Return to Rigging and Sails
