Surveying an F38
Surveying an F38
Postby gamayun » Thu Dec 13, 2012 12:55 am
I just put an offer on a Freedom 36/38 (sloop). If the owner accepts, I plan to get vessel and engine surveys done at the beginning of the year. It would be great to find a surveyor who's experienced with the Freedoms. Regardless, I am interested in hearing from others about what things I should definitely check out or be aware of. It looks like the equipment and sails have not been upgraded for at least the past 12 years, and I have noticed some corrosion in places, but repairs seem to have been made when needed and most everything currently on the boat is in working order. Do you think I should get someone to climb the mast? I am also be interested in hearing about what upgrades would be most important to do right away.
Thanks for all suggestions!
gamayun
Re: Surveying an F38
Postby moosemcclintock » Thu Dec 13, 2012 2:10 pm
You didn't say where you are but Dwight Escalera is a Marine Surveyor who worked for Freedom for years commissioning. He also owned a Freedom 32 (I think) for a long time, you can't find a better guy. He's in RI, where are you located?
moosemcclintock
Postby gamayun » Thu Dec 13, 2012 3:16 pm
Ah yes, I'm on the west coast, near San Francisco. But this is good because he might know someone out here or at least suggest some of the things to look out for. Thank you.
gamayun
Postby sailmon » Fri Dec 14, 2012 6:29 pm
Amazing boats. We're planning to retire and go cruising on our 1991 F38. One of the biggest survey issues with Freedoms (or any cored hull) is to make sure there is no water incursion or moisture in the balsa core. Same goes for the deck core.
S/V Her Diamond
1991 Freedom 38
Cleveland, OH
sailmon
Postby gamayun » Fri Dec 14, 2012 9:07 pm
I emailed Mr. Escalera today and he offered to contact someone on the west coast. Thanks for the contact. I am aware of the cored deck and hulls and plan to ask the surveyor how he assess that. I read a good article recently about the vagaries of taking readings from a moisture meter. I appreciate the input. From what I can tell, Freedom owners love these boats....
gamayun
Postby RW Rawles » Sat Mar 30, 2013 9:34 pm
gamayun wrote:I just put an offer on a Freedom 36/38 (sloop). If the owner accepts, I plan to get vessel and engine surveys done at the beginning of the year. It would be great to find a surveyor who's experienced with the Freedoms. Regardless, I am interested in hearing from others about what things I should definitely check out or be aware of. It looks like the equipment and sails have not been upgraded for at least the past 12 years, and I have noticed some corrosion in places, but repairs seem to have been made when needed and most everything currently on the boat is in working order. Do you think I should get someone to climb the mast? I am also be interested in hearing about what upgrades would be most important to do right away.
I have both a good Freedom-38 for sale and a good Freedom-38 surveyor. Both West Coast! (Do we know each other?)
RW Rawles
Postby gamayun » Sun Mar 31, 2013 12:40 am
Hi. I don't think we know each other. The sale went through in late January. Since then, I have driven to San Diego 3 times and spent hours learning about the new "Kynntana." so I am not in the market for a boat or a surveyor, but am curious where is your boat?
gamayun
Postby RW Rawles » Sun Mar 31, 2013 1:59 am
gamayun wrote:Hi. I don't think we know each other. The sale went through in late January. Since then, I have driven to San Diego 3 times and spent hours learning about the new "Kynntana." so I am not in the market for a boat or a surveyor, but am curious where is your boat?
Sent you a private message.
RW Rawles
Return to Random Chatter
