Freedom 28 Cat Ketch Specs
Freedom28OriginalPriceSheet.pdf
F-28 Original Price Sheet
(719.52 KiB) Downloaded 1642 times
F28 Specs.pdf
(403.16 KiB) Downloaded 2249 times
peaceandfreedom
Re: Freedom 28 Cat Ketch Specs
Post by peaceandfreedom »
Here are three more files for the F28 CK with fixed keel and conventional booms.
happy sailing
Jim D
F28 CK fixed keel.pdf
owners manual
(1.56 MiB) Downloaded 1511 times
F28 CK info.pdf
F28 CK info
(456.12 KiB) Downloaded 1502 times
F28 CK Specifications & Options.pdf
specifications and options price list
(167.38 KiB) Downloaded 1431 times
VeloFellow
Post by VeloFellow »
I believe greg's download is for the freedm 2-28 cat not cat ketch.
s/v Clave'
1981Freedom 28 #112
Currently sailing Tampa Bay
yanmar 2ym15 2blade prop
cmaxwell
Location: freedom catketch wishbone-centerboard 1981 tollotson & pearson inc.
Post by cmaxwell »
I have general specs and rigging info for a F28 wishbone centerboard - I'm looking for sail specs for a wrap-around main and mizzen - or a sail maker who has them and is willing to give them up.
Goose13
Post by Goose13 »
Haarstick should have the specs for the wrap around sails, I inquired about new wrap arounds for a F33CK. They will try and talk you out of it and getting new one piece sails and going with a track on your mast. Personally I won't go that route because I don't want to drill holes in my masts and looking at the G10 set up I think I'm going to try and go with that. It gives full battans, more roach without adding a track system. I probably won't be getting new sails for at least another year yet.
Doug and Marie
cmaxwell
Post by cmaxwell »
Once up, wishbone sails are the best and easiest to handle single-handed. No one ever mentions the great advantage to having a steady banister to hold on to going forward. I'm still surfing to find sail dimensions. So far no luck.
Martijn
Post by Martijn »
The original wrap around sails were made by ulmer sails, not haarstick. Ulmer sail is now UK sailmakers.
1980raven
Post by 1980raven »
If you are located in the USA you can contact Thurston Quantum sails, Bristol, RI. Last June I had Steve Thurston out for a test sail on Raven. He took some dimensions of my rig and concluded that my sail are cut (Ulmer) to the original specifications. He indicated he and Gary Hoyt sailed a F28 CK in the early 80s and came up with slightly smaller sails that improved the boats handling, clearence in the cockpit and over the deck. He quoted me about $8k for a new main and mizzen. After looking at other rig posabilities and distilling what others have said on this forum I am keeping the wishbones and the wraparound sails. I haven't ordered new sails yet but I will be some time next year.
Narragansett Bay, RI
VeloFellow
The Freedom 30 Cat Ketch is the US Freedom 28. Here is the link to he documents which apply to the TPI Freedom 28 Cat Ketch as well. More variation through the years than across the ocean?
http://www.freedomyachts.org/viewtopic.php?f=16&t=12051
s/v Clave'
1981Freedom 28 #112
VeloFellow
Freedom 28 (UK30) cat ketch hull numbers
My 1981 Freedom 28 (UK 30) cat ketch is #112
I wondered if the UK builders were assigned starting with #100?
To those of you with Freedom 28 cat ketches or F30 cat ketches in Europe, how about year of production and hull number.
I know the Freedom 30 cat ketch was produced longer in England but curious as to how many and when.
The first Freedom 28 Cat Ketch I went on was #3 built by TPI in 1979.
s/v Clave'
1981Freedom 28 #112
