Mast height F36 cat sloop
Postby CaptLen » Tue Apr 12, 2016 3:23 pm
I'm just buying an F36 sloop and have to clear a fixed bridge with vertical clearance of 65'- can anyone tell me what the height above water is for this model? Tidal range is 4.5' which may help...
Thanks in advance for any help
CaptLen
Re: Mast height F36 cat sloop
Postby bad » Wed Apr 13, 2016 10:25 am
So a quick look on the internet showed your P dimension of your main (luff) to be 45ft. Even if your boom is 10 ft above the water, that only gets you to 55 ft. You possibly have an antenna or Windex on top, too. You got lots of room...
If you want to double check free advice off the internet... Consider measuring the height. For a conservative measurement, do the toerail to water and using the halyard, mast to toe rail.
bad
Postby CaptLen » Thu Apr 14, 2016 11:37 am
Thanks, Eric- We'll be doing the survey this weekend so I'll take my 100' tape measure- thought someone might know offhand. Thanks for the reply.
CaptLen
Return to Manuals and Documentation
