Replaced my ARS-4 Balmar voltage regulator, want it?
Ereiss
Post by Ereiss »
I replaced my old ARS-4 with a more modern unit. If you would like it I would be happy to send it to you for the cost of the postage. I hate throwing working things away. You will probably need the wiring harness (but not necessarily), but it isn't expensive.
Let me know if you can use it.
Re: Replaced my ARS-4 Balmar voltage regulator, want it?
What did you replace it with?
P.S. If no one else wants it, I would be glad to take it as a spare as mine had the top blown off with the lightning strike and I'll be replacing it.
Ereiss
Post by Ereiss »
I replaced it with the Balmar 614 which reads the voltage at the battery and adjusts the output to ensure I'm getting the 14.3 that I need for my agm batteries. Also much easier to program with readout vs idiot lights. I also now have battery temp sensing in addition to the alternator temp that I always had.
Ereiss
Post by Ereiss »
Want to give me an address to which I can send the faithful old unit?
Ed,
I was traveling all of last week & missed your replies. We went to St. Louis to watch the eclipse and then headed to Memphis & Nashville. I've had my fill of BBQ and country music! Anyhow, I sent you an e-mail regarding this.
Much appreciate it.
