Propane tank
Re: Propane tank
Postby Camino » Wed Sep 27, 2017 8:23 pm
Mike - would you be able to pm me as to your vendor? :D
Re: Propane tank
Postby BillSmith » Wed Sep 27, 2017 11:28 pm
Me Two! Got two slim cylinders that I am sure will be out of spec and do need to be filled.
Bill & Carole Smith
Freedom 35 Pedrick
SweeTART
Coyote Point
San Mateo, CA
BillSmith
Re: Propane tank
Postby F32Circle » Thu Sep 28, 2017 11:05 am
Our local (Connecticut) gases and welding supply company replaced the valve and decertified our tank with no issues.
I think I saw a new tank of this type and size at West Marine, so that could also be an alternative.
F32 Hull #67
F32Circle
Re: Propane tank
Postby mike cunningham » Thu Sep 28, 2017 11:41 am
for the central valley
Campora Propane, Stockton
For the bay area
Ideal RV and Trailer Supply, Redwood City
Both can be found online
I didn't mention Ideal in my original post but they are knowledgeable and non-bureaucratic. They try to help as opposed to trying to obstruct.
Last edited by mike cunningham on Thu Sep 28, 2017 6:00 pm, edited 1 time in total.
Re: Propane tank
Postby Camino » Thu Sep 28, 2017 11:55 am
Tanks, Mike! :D
Re: Propane tank
Postby ketch22 » Thu Sep 28, 2017 12:02 pm
About a month ago, I had a tank rebuilt abd certified in San Jose:
AmeriGas Propane
Propane Supplier
1.7 mi · 1155 N 15th St
(408) 293-1252
Tom
Ketch 22
ketch22
Re: Propane tank
Postby mike cunningham » Thu Sep 28, 2017 6:02 pm
Yes, I think any big propane supplier will be good. Many have minimum charges so be aware that a couple gals of propane is likely to cost $15 or so.
Re: Propane tank
Postby northerncole » Sun Oct 01, 2017 9:17 pm
Thanks for all the great information. I'm going to see the guy tomorrow and if he hasn't done the job I'll use one of your contacts.
Yes it is all a cash grab.
northerncole
Re: Propane tank
Postby northerncole » Tue Oct 03, 2017 4:24 pm
Big surprise. They claim the valves in them are illegal in Canada now and they can't recertify them. Guess we'll be heading to WA with them to see if we can find someone more helpful. Joys of living in BC.
northerncole
Re: Propane tank
Postby dwight » Wed Oct 04, 2017 9:30 am
The old valves are illegal in the USA as well. That's why you need to change it.
I just Googled "replacement OPD propane valve" and see an OPD valve is available online for $26.58. In the same Google search results was a website describing the replacement procedure. Could be DYI.
All propane tanks need to be hydro tested every 12 years, so they should be able to handle that.
Dwight Escalera
former Freedom Engineer,
former owner
F36-71
Wakefield, RI
dwight
PreviousNext
