Hello all ~
All I wanted to replace this 30 year old worn sheave. But, then I noticed the retainer at the end of the spar is frozen in place. I can turn it with water pumps but I don't think it should be that tight. Seems it would not rotate with the wind to give me proper shape on a tack. I'm I not understanding the mechanical process that is taking place on a tack regarding the camber spar?
Help guys!
Hoyt 32 CamberSpar sheave
- gulfcoastsailor
- spar.png (43.61 KiB) Viewed 5726 times
Chip
"Encore"
Freedom 32
1985 #72
"Encore"
Freedom 32
1985 #72
- JohnReinagel
Re: Hoyt 32 CamberSpar sheave
Hello Chip, yes that end has to swivel freely.
- drcscruggs
Fwiw,
I have had good luck just using wd40 and working items that have similar restrictive corrosion. Haven’t done this in this particular instance. Best
- gulfcoastsailor
Thanks, guys. Got it working properly with new parts as well.
Chip
"Encore"
Freedom 32
1985 #72
"Encore"
Freedom 32
1985 #72
Hi Chip,
I’m looking to replace my sheave this season. Where did you get your parts? How did you get it out of the end of the camberspar?
- gulfcoastsailor
I got the Parts from
http://www.warrenriverboatworks.com/
Removal? 2 guys, 2 water pumps and good ol’ WD40.
Chip
"Encore"
Freedom 32
1985 #72
"Encore"
Freedom 32
1985 #72
